[SOLVED]Normal Intensity For Mantra Surface?
Atom
Hi All,
I am surprised to discover that the Mantra Surface has no intensity value for a normal map. I have tried adding in a multiply node in the VEX Builder but it seems to have no effect. How do I pull back the intensity of the normal map?
Edited by Atom
I haven't checked mantra surface, but (tangent) normal maps represent an offset from the surface normal, so in the end they represent a new direction of the surface.
The intensity you are looking for would be how much your normal is shifted in that other direction, so you might want to blend the normal map between its value and  a neutral one.
http://wiki.polycount.com/wiki/Normal_map
if you look at Flat Color, it tells you that
The color (128,128,255) creates normals that are completely perpendicular to the polygon, as long as the vertex normals are also perpendicula
 so If you try to blend your normal map values back to (0.5, 0.5, 1) you should have no offset and no "intensity"
I would try that
