uv transfer problem
keqiquan
Hi guys
 I have a question about the uv transfer.
When I have a simple  two points arising out of the curve then into skin and transfer uv can be work.but, when I  use multi point, and then transferred to the skin, UV rays
flashing after the transfer, would like to ask how to solve.
Cheers.
Edited by keqiquan
it's all about your vertex order
since you are building the skin from lengthwise curves, the first row of polygons will always be along the length, then second along the length etc.
that means that short tube and long tube will not have matching indices
you can use one skin sop to generate crossection profiles and second to build skin from them
therefore it will be built incrementally from the base and the indices of short tube and long tube will match
uv_transfer_fix.hip
Thank you for providing the requested information.   anim
