Adding time to cloudnoise
ValentinD
Hi everyone !
I'm doing some clouds with CloudFx and I wanted to animate them a bit.
For the moment I have tried to set an expression to the offset of the cloudnoise but I'm not very happy with it... The patern is sliding on the cloud which is not convincing...
I am pretty new to the world of VOP but I have seen that inside the cloudnoise stands a Volume VOP (cloudnoise), I know that I have to add time inside of it, but does not understant how...
Is it possible to have some help ? Thanks !
ValentinD
Hello,
One option would be to pipe whatever you are making the clouds from into a pointVOP.
Stick some curl noise (with built in pulse length) or a turbulent noise (using time on the offset parameter) on the position/displacement.
You could use this to get some underlying noise on the base shape. Add the cloud rig built in noise over the top. Finally finish with some shader noise/displacement.
