jkunz07 Posted September 26, 2015 Share Posted September 26, 2015 Hey, I'm trying to match the translation and rotation of another set of points using the svd function in numpy The code I have right now is below: (Some of it I got from here http://nghiaho.com/?page_id=671) import numpy, math node = hou.pwd() geo_A = node.geometry() if node.inputs()[1] != None and len(node.inputs()) >= 2: geo_B = node.inputs()[1].geometry() string_buffer = geo_A.pointFloatAttribValuesAsString("P", float_type=hou.numericData.Float32) #get array of all points attr "P" as string buffer array_of_pos_A = numpy.fromstring(string_buffer, dtype='float32' ).reshape(-1, 3) # reshape to make it 2dimentional (array of vectors) string_buffer = geo_B.pointFloatAttribValuesAsString("P", float_type=hou.numericData.Float32) array_of_pos_B = numpy.fromstring(string_buffer, dtype='float32' ).reshape(-1, 3) N = array_of_pos_A.shape[0]; # total number of points min_bbox_A = numpy.min(array_of_pos_A, axis=0) max_bbox_A = numpy.max(array_of_pos_A, axis=0) centroid_A = (min_bbox_A+max_bbox_A) / 2 min_bbox_B = numpy.min(array_of_pos_B, axis=0) max_bbox_B = numpy.max(array_of_pos_B, axis=0) centroid_B = (min_bbox_A+max_bbox_ / 2 AA = array_of_pos_A - numpy.tile(centroid_A, (N, 1)) BB = array_of_pos_B - numpy.tile(centroid_B, (N, 1)) H = numpy.dot( numpy.transpose(AA), BB) U, S, Vt = numpy.linalg.svd(H) R = Vt.T*U.T # special reflection case if numpy.linalg.det(R) < 0: Vt[2,:] *= -1 R = Vt.T * U.T t = -R*centroid_A.T + centroid_B.T print 't : '+str(t)+'\n\n' print 'R : '+str(R)+'\n\n' geo_A.setPointFloatAttribValuesFromString("P", numpy.getbuffer(AA), float_type=hou.numericData.Float32) # Put the values back to the geo point position attr I can see 't' and 'R' matrices print out, but any attempts of actually transforming the first input geometry by them have resulted in broadcast errors. Additionally, any attempts to output them as geometry attributes have failed as well. numpy_svd_test_v002.hip Any help here would be greatly appreciated ! Quote Link to comment Share on other sites More sharing options...
petz Posted September 27, 2015 Share Posted September 27, 2015 that should do the trick ... node = hou.pwd() geo = node.geometry() geoRef = hou.pwd().inputs()[1].geometry() import numpy as np posArray = np.asarray(geo.pointFloatAttribValues("P")).reshape(-1, 3) posArrayRef = np.asarray(geoRef.pointFloatAttribValues("P")).reshape(-1, 3) centroidRef = np.mean(posArrayRef, axis = 0) centroid = np.mean(posArray, axis = 0) posArrayRef -= centroidRef covar = np.dot(posArray.T, posArrayRef) u, s, v = np.linalg.svd(covar) rotMat = np.dot(u, v) mat = hou.hmath.buildTranslate(-centroid) mat *= hou.Matrix4(hou.Matrix3(rotMat)) mat *= hou.hmath.buildTranslate(centroidRef) geo.transform(mat) hth. petz 4 Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted September 27, 2015 Author Share Posted September 27, 2015 Yes, it works ! Thanks for your help Quote Link to comment Share on other sites More sharing options...
RayFoundry Posted April 10, 2018 Share Posted April 10, 2018 On 27.9.2015 at 5:28 PM, petz said: that should do the trick ... node = hou.pwd() geo = node.geometry() geoRef = hou.pwd().inputs()[1].geometry() import numpy as np posArray = np.asarray(geo.pointFloatAttribValues("P")).reshape(-1, 3) posArrayRef = np.asarray(geoRef.pointFloatAttribValues("P")).reshape(-1, 3) centroidRef = np.mean(posArrayRef, axis = 0) centroid = np.mean(posArray, axis = 0) posArrayRef -= centroidRef covar = np.dot(posArray.T, posArrayRef) u, s, v = np.linalg.svd(covar) rotMat = np.dot(u, v) mat = hou.hmath.buildTranslate(-centroid) mat *= hou.Matrix4(hou.Matrix3(rotMat)) mat *= hou.hmath.buildTranslate(centroidRef) geo.transform(mat) hth. petz Very useful, thank you! This does only work when the point count on both geometries is the same though. Any idea how to extend this for cases where the point count is not the same? Quote Link to comment Share on other sites More sharing options...
