[SOLVED]CrowdTrigger VEX Can't Access Channel?
Atom
Hi All,
I am trying to add a random seed to my VEX code in a Crowd Trigger. But it seems like there is a bug, using H14.396. The result is always zero. If I place this same code in a PopWrangle, it works, however.
Is there some other syntax required to fetch a value from a channel using VEX?
post-12295-0-66706200-1443647310_thumb.j
Edited by Atom
The Evaluation Node Path parameter on the POP Wrangle inside the HDA was left at its default, so the ch() expressions were evaluating relative to that node rather than the top level node where the snippet comes from. I've fixed that in tomorrow's build (14.0.473) and parameters for the four geometry inputs are also now exposed.
Cool, thanks Cameron.
I was also noticing another VEX oddity. That i@crowdtranstion is never valid except inside a Crowd Trigger VEX snippet. If I put the same code in a PopWrangle , on the second input of the CrowdSolver (CrowdTriggers come in on the third input), i@crowdtranstion is always zero.
Edited by Atom
