Guest xionmark Posted November 30, 2004 Share Posted November 30, 2004 Hi there, I need to create a few custom camera projections to be used for a mapping project that is currently written in IDL but I want to port the whole thing to Houdini because of the superior image capability of Houdini. The only thing I need to figure out is how to do a custom camera projection, specifically a "Robinson" projection. The other projection types I deal with, "Cylindrical", "Satellite". and "Mercator" I'm pretty sure I can handle with the current camera projection types. I've looked around the web for info regarding "Robinson" projections and found that the projection is done through a table of values instead a formula; curious. I haven't found said table of values but am on the hunt for them. My question is would I have to write a custom camera with the HDK to accomplish this? I've looked through the HDK samples and didn't find anything like what I need. The OBJ_Camera class doesn't seem to have a way to use your own projection. Any suggestions of where to start? Thanks! --Mark Quote Link to comment Share on other sites More sharing options...
Sheff Posted March 26, 2013 Share Posted March 26, 2013 (edited) Is there any progress in doing custom camera? I need to create raytrace fisheye projection, not from cube map or with fog shader. So trying to figure out where can i do that. Edited March 26, 2013 by Sheff Quote Link to comment Share on other sites More sharing options...
dgani Posted November 21, 2017 Share Posted November 21, 2017 I would also like to know where to start dealing with cameras. Has anyone gotten anywhere with this? Any functions or documentation to look at? Quote Link to comment Share on other sites More sharing options...
symek Posted November 21, 2017 Share Posted November 21, 2017 Afaik HDK doesn't expose any headers for Mantra's camera, but you might take a look into lens shaders, like ASAD lens shader (v_asadlens shop) to control camera projection. Quote Link to comment Share on other sites More sharing options...
mestela Posted November 21, 2017 Share Posted November 21, 2017 I have some notes on making a camera shader here, and the game shelf has a cool fly eye/imposter generator camera you can pull apart. http://www.tokeru.com/cgwiki/?title=HoudiniOculusWip 1 Quote Link to comment Share on other sites More sharing options...
djiki Posted December 8, 2017 Share Posted December 8, 2017 Yes. Houdini, to be more precise, Mantra allows you to do any kind of projection you can imagine using custom lens shader. I wouldn't call that projection because it is much more. You can create your own rays (their origins and directions) for each rendered pixel and do manual ray trace not only in lens shader but in any kind of shader. Off course, you have to figure out first what "Robinson" table data represents and then we can help. Quote Link to comment Share on other sites More sharing options...
Sumit Posted January 23, 2018 Share Posted January 23, 2018 https://en.wikipedia.org/wiki/Robinson_projection The projection is defined by the table: Latitude PLEN PDFE 00 1.0000 0.0000 05 0.9986 0.0620 10 0.9954 0.1240 15 0.9900 0.1860 20 0.9822 0.2480 25 0.9730 0.3100 30 0.9600 0.3720 35 0.9427 0.4340 40 0.9216 0.4958 45 0.8962 0.5571 50 0.8679 0.6176 55 0.8350 0.6769 60 0.7986 0.7346 65 0.7597 0.7903 70 0.7186 0.8435 75 0.6732 0.8936 80 0.6213 0.9394 85 0.5722 0.9761 90 0.5322 1.0000 The table is indexed by latitude at 5 degree intervals; intermediate values are calculated using interpolation. Robinson did not specify any particular interpolation method, but it is reported that he used Aitken interpolation himself. The PLEN column is the length of the parallel of latitude, and the PDFE column is multiplied by 0.5072 to obtain the distance of that parallel from the equator. Meridians of longitude are equally spaced on each parallel of latitude. Quote Link to comment Share on other sites More sharing options...
