cloth stretch
Rio.Dominia
This will probably do it. See attached. Click on gif to show animation
Thanks. It helps a lot .   But , if I use an Animated object to collied with this cloth.  There still had some problem.
1. when the two object strech so much. in some frame the cloth Will be interspersed .
2.the imported Animated object can not surport the cloth constraint on its surface. I tried it so many times, And when I select the collied object's surface. Houdini crashed.  I don not konw the reason.
3.It's easy to find the constraint point in the cloth in one project.  But if I want make an otl , such as Bubble gum stick on people's body.  If I have 50 shots  It's hard to select the constraint points everytime,That's so manual ! How to solve this?
Check the attached .hip- in essence you can use groups to define the constrained points, either defined by an attribute or a bounding object would seem to be the best.
Answers for the points:
1. Not sure what this means. Do you have a visual example of the issue?
2. Groups can be used. The crash is not good, please send it into SideFx as a bug.
3. Groups can be used.
Animated2.hipnc
Edited by tar
