scattered wires ! please help
90okm
Hi !
I'm trying to simulate wires scattered on surface.
there is a simple dopnetwork in the attached file.
Whatever wire parameters i set these wires do not want to deform according to default gravity force. it reacts on gravity only when i set very large amount of force.
I think that it's not a good idea to override gravity with some unnatural value, but i can not find correct physical parameters for wires in order to force them to act correctly with normal gravity value
any kind of help will be appreciated/
wires.hip
Edited by 90okm
I don't know how much you want your wire to be moved...
However,
Physical
Density 1500
Width 0.03
Elasticity
Linear S 5
Linear D 0
Angular S 10
Angular D 1
It moved just with the default gravity force.
When something's are not working, try putting crazy values on the parameter.
Edited by bluciensky
