Pyro Heat Field Interpolation
gpapaioa
Hello. I am doing a Pyro retime using the qLib tools for volume retiming. It works quite good but only for density. The resulting heat and temperature fields are not interpolating correctly, they seem to be just a copy of the density field. Any ideas on how to retime pyro with another way? Thanx
Hi Georgios,
I am currently facing the same task, what qlib node are you using?
You can also try using the volume mix method, which has given me ok results. Still a bit stepy.
It's not my website, but you can find a sample otl here:
http://www.jamescharles.com/projects/slow_motion_tut/slow_motion_tut.html
Do you know if I have to install the complete qlib library to see it?
If I look inside the folders of qlib.0.2.5 I can't see it, so it must be contained in another otl?
Do you know which one?
Thanks,
Cris
