BrianK Posted August 27, 2005 Author Share Posted August 27, 2005 Got a windows (cygwin) version running as well. It takes a good bit of effort to get cygwin running smoothly with hdk, but the make and ml_hcustom remain pretty similar. See this thread on making cygwin happy. you'll have to edit hcustom.nt just a bit. Change this line set IFLAGS = "$INCINC -I . -I $MSVCDir/include -I $HFS/custom/include -I $HFS/toolkit/include" to set IFLAGS = "$INCINC -I . -I $MSVCDir/include -I $MSVCDir/PlatformSDK/Include -I $HFS/custom/include -I $HFS/toolkit/include" Then, in ml_hcustom, change this line: sed /\$SHARED/s/\$CC/\#\ \$CC/g `which hcustom` | sed s/hcompile/hcompile\ -t/g > newhcustom && chmod u+x newhcustom to sed /\$SHARED/s/\$CC/\#\ \$CC/g `which hcustom`.nt | sed s/hcompile/hcompile\ -t/g > newhcustom && chmod u+x newhcustom ... Then the makefile is also pretty similar: LIBDIR = LIBS = INCINC = -I ../../MLInclude/ files:= $(wildcard *.C) objects:= $(files:%.C=%.o) hcustomfile:= SOP_RibFile.C %.o : %.C ./ml_hcustom $(INCINC) $< ar -rv libforme.a $@ rm -f ~/houdini$(HOUDINI_MAJOR_RELEASE).$(HOUDINI_MINOR_RELEASE)/dso/$(<:.C=.dll) $(hcustomfile:.C=.o): $(hcustomfile) $(hcustomfile:.C=.h) $(objects) hcustom -l libforme.a $(LIBDIR) $(LIBS) $(INCINC) $(@:.o=.C) clean: rm -f *~ *.o *.a cleandso: rm -f *~ *.o *.a ~/houdini$(HOUDINI_MAJOR_RELEASE).$(HOUDINI_MINOR_RELEASE)/dso/$(hcustomfile:.C=.dll) Note the rm in the .C -> .o rule... hcompile for windows doesn't create a .o that later gets compiled with g++, rather, it makes the actual dll in addition to the .o, SOoo every file creates a .dll in your dso dir unless you remove it. If you don't remove it/them, you'll just get some errors when you load houdini. For some reason, the rm above isn't working on my machine - I can't seem to delete files unless they are in ./ - I guess that's something weird with my cygwin setup. So there ya go... Linux & windows makefiles for houdini. maybe this is old news to some, but it's been a pain in my side for quite some time now. Quote Link to comment Share on other sites More sharing options...
eloop Posted August 27, 2005 Share Posted August 27, 2005 I've gone the makefile route because for the life of me I couldn't get the windows hcustom to work properly when linking .lib files. I have a strong suspicion there is a bug in there somewhere, the linux version works as you'd expect. It did give me the motivation to build a single Makefile that works across both cygwin win32 and linux for the HOT. Check out the source for an example. I had to include a modified version of Makefile.linux from the HDK due to a minor bug, apparently now fixed. -Drew Quote Link to comment Share on other sites More sharing options...
