Fostertron Posted October 13, 2015 Share Posted October 13, 2015 Hi Guys, Another newbie question. I create surfaces in Rhino and I'm trying to import as an obj. I import, and try to animate but after frame 1, the data dissapears. The scale and orientation is also incorrect but one thing at a time Here's the file, Import Issue.hipnc Thanks for any help! Quote Link to comment Share on other sites More sharing options...
Atom Posted October 13, 2015 Share Posted October 13, 2015 (edited) Probably just a naming issue. For instance, your file node is referencing a .dxf, not an .obj. You also have $F in your file name. Are you working with a series of .OBJ files or just a single one? Edited October 13, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
Fostertron Posted October 13, 2015 Author Share Posted October 13, 2015 Thanks so much for the quick reply. Sorry, yes this one is an FBX, I've been trying different formats. It's just a single model. Quote Link to comment Share on other sites More sharing options...
Fostertron Posted October 13, 2015 Author Share Posted October 13, 2015 Thanks Atom, that did the trick! The file name was 'test 1'. I had no idea houdini would treat it that way! Thanks again, more stupid questions to follow...... 1 Quote Link to comment Share on other sites More sharing options...
