detect hda def changes reliably
eyevex
I thought I had stumbled across this at some time via hscript or hython...
Basically checking an unlocked HDA  defined node to see of any different since saved last.
I would think matchesDefinition() would serve this purpose but seems identical to isLocked()
Proof seems to be getting a py ref to a hda defined node, test... True, then unlock -- no other changes... test... False.
I could make some ugly use of modification stamp ... but this has its own issues ...
I unlocked, RMB save is always enabled even before any modification is made.
If saved anyway stamp is updated...
Thoughts?
[eyevex] (|;-D>
The only idea I currently have that would seem reliable....
extract definition contents, parse contents section and compare the node graph against it.
This would be a bit more time than I have to gain this functionality right now and would have to assume something exosts that could get me closer as a starting point....
ir not?
(|;-D>
You could try the new 'otldiff' command-line tool in Houdini 15
$ otldiff
otldiff: Wrong number of OTL paths specified.
otldiff 1/infinity
Description:
  Visually compare the contents of two OTLs. Similar to 'svn diff'.
Usage:
   otldiff [options] file.otl
   otldiff [options] fileA.otl fileB.otl
Options:
     -h,     --help          Print this message
     -r,     --revision      Specify revision(s) to compare.
Examples:
  Compare two OTLs:
     otldiff oldfile.otl newfile.otl
  Compare current with a previous revision:
     otldiff -r 12345 current.otl
  Compare two distinct revisions:
     otldiff -r 1234:6789 file.otl
I'm not sure that'll work in this case. Although I was unaware and that is super useful to know …
Although it does have some possibilities but they could get ugly.. and involve a lot of definition swapping.
I wrote the subject  line quickly...
# More accurately …. lets say ….
my_node = hou.node('/some/meaningful/oppath')
my_nodes_def = my_node.type().definition()
# Now we edit the contents ….
my_node.allowEditingOfContents()
#…. Now in the net pane you can save. This would change the def and stamp ala ...
my_nodes_def.modificationTime()
# as well as potentially some other user oriented data
# these will always return the same values
my_node.isLocked()
my_node.matchesCurrentDefinition()
# ….. So in terms of both representation and functionality and preferably without custom parsing the contents of the different sections of …
my_nodes_def.sections()
# … and attempting to compare it to the current node graph and parameter interface, script section etc .. know if the unlocked my_node has actually changed (beyond time stamp and user etc .. that goes with saving when no changes have happened) from how it is described by my_nodes_def
...I spouse more options for saving and update from node mechanism would solve this too where there was a force option or wouldn't save when there were no changes… but am trying to do something that I can work with now.
Hopefully the problems a little clearer.
(|:-D>
according to help hou.Node.matchesCurrentDefinition() should be doing that
as it says:
Return whether the contents of the node match its type definition. A locked digital asset instance will always match its definition, but an unlocked one may not.
so if it's not doing that maybe report a bug
