David Gary Posted December 5, 2004 Share Posted December 5, 2004 Hi. I recently downloaded Houdini 7 nc I have problems using the new help infrastructure : the embedded browser seem not to work ... anymore. Moreover, i'm not always connected to internet. Is there a way to browse the help offline? thx for help Quote Link to comment Share on other sites More sharing options...
edward Posted December 8, 2004 Share Posted December 8, 2004 I'm usinig 7.0.231 on WinXP and it works fine ... Are you on Linux? After you source houdini_setup (or houdini_setup_bash), check to make sure your JAVA_HOME environment is pointing at the right thing. Quote Link to comment Share on other sites More sharing options...
David Gary Posted December 9, 2004 Author Share Posted December 9, 2004 Ahem i'm on Windows 2000. ( so i didn't set any variable like i used to when i was on Linux) the installation is straightforward . How/where do you set this kind of variables under Win2000/XP? Quote Link to comment Share on other sites More sharing options...
keltuzar Posted December 10, 2004 Share Posted December 10, 2004 try uninstalling it and downloading the new version of the apprentice version .... maybe it will work then... but I have to say the new help system is worth the look... its much more better than those old pdfs they used to have.... hope it helps Quote Link to comment Share on other sites More sharing options...
edward Posted December 11, 2004 Share Posted December 11, 2004 I have no idea then. Quote Link to comment Share on other sites More sharing options...
George Posted December 11, 2004 Share Posted December 11, 2004 How/where do you set this kind of variables under Win2000/XP? 15417[/snapback] The environment variables in Windows are accessible from Control Panel, System, Advanaced tab, Environment Variables (button at the bottom). Of course if you are using cygwin or something similar, you can just use the shell's environment variables as in Linux. Hope that helps. Quote Link to comment Share on other sites More sharing options...
birras Posted December 12, 2004 Share Posted December 12, 2004 The environment variables in Windows are accessible from Control Panel, System, Advanaced tab, Environment Variables (button at the bottom). Quote Link to comment Share on other sites More sharing options...
deecue Posted December 13, 2004 Share Posted December 13, 2004 hey birras, if you want to find out the 8-character version of your windows folder/file names (i.e. program files/documents and settings), you can always find out at the command prompt. there are two different command prompts for XP, the old and the new. The old diplays the 8-character folders at the prompt where as the new one shows the full length folder name with spaces. the old one is 'command' and the new one is 'cmd'. it doesn't matter which one you use because you can still find out what the 8-character equivilant is on either one. so just go to start menu->run and type 'command' or 'cmd' and hit enter. you will start off in your user directory. you will use the 'dir /x' to see a listing of files and folders in the current folder you are in and will also see a column with the 8-character equiv's. so if you want to know program files or whatever, just type 'chdir c:\' enter and then 'dir /x' to see the listing of folders with a column based on the 8-character version. You see program files and see what the 8-character version is next to it. For example program files is progra~1, not programm~. And documents and settings is docume~1, not documents~. hth, dave Quote Link to comment Share on other sites More sharing options...
