Init Pop Grain Explosion
Hi, i'm facing a problem that is really annoying.
I'm trying to setup a pile of grain on a non-flat surface and the volume I use has part of it inside the non-flat surface. (If i'm not clear, the HIP with my message show a basic setup of what i'm trying to do)
At initialization, all the grain are exploding. I tried to use a PopWrangle with "@v = 0" for the first two secondes but it does a weird thing. I tried having 10 Substeps + 150+ Constraint Iterations but same, doesn't change anything and it's still exploding.
If someone can explain to me what i'm doing wrong. Would be amazing :)
Thank you !
Grain_Init.hip
Thank you !
And I want to ask you one more question. My pile is like melting on the floor until it's completly flat. How can i keep the shape i get from my geometry ? If I want to keep a pyramide or a box with noise on it for example ?
Many thanks.
Edited by Kirosana
