Partilcles - matte for selecting static ones?
cwalrus
Thanks Sankar - but that won't work for me. The particles come to rest when the hit the ground, so if I simply delete all the particles with velocity, they will die before they do anything (and they hit the ground at different times)
Also, i need a solution that works in a production setting - i.e. hit the render button once, and then I get one pass of all the particles, and one pass which is just a matte for the static particles.
Help!
thanks!
Dude! Blu to the rescue as usual! Thanks man - i had no idea AOV's even exisited. This is great news.
Now I've typed in length($VX,$VY,$VZ) = 0  into the VEX Variable field on the AOV / extra image planes and I"m getting nothing.  Do i need to 'introduce' the particles velocity somehow, or write different code there?
Thanks Sankar as well - going to look into the grouping work around now...
Edited by cwalrus
You want to make it as an attribute. For example, make an attribute called 'velzero' whatever the length of 0 is red (1,0,0) otherwise blue (0,0,1). You do this on SOP (or shader... up to you)
Have this attribute on your shader(using bind, and export it), then put the attribute name on your AOV VEX Variable and channel name(this can be different name).
Holy bat pee so helpful guys -
Thanks Sankar- that file explained so much - and It's reallllllly hard to learn that without help from people like you.
Blu I'm going to try to do what you suggested also at some point - haven't played with Bind before now...
Hi again guys -
Sankar, the DirectRender option works perfectly, but I tried to replicate your other tree- the AOV tree, with no luck. Can you see what I've neglected if you have a second?
thank you!
You must Assign a shader to the particles, Inside the shader create a parameter node and change the settings as per your attributes (Check the attached images)
Then add extra image planes and give the attribute name in mantra
post-6051-0-44958900-1445355405_thumb.jp
post-6051-0-80772900-1445355412_thumb.jp
