Juraj Posted October 21, 2015 Share Posted October 21, 2015 Hello, I have few questions about DOPs: What is correct way of importing packed objects during simulation into DOPs? So far I have been doing it this way: RBD Packed Object with Creation Frame set to $F, and in SOPs I have geometry only on frame when I want it to import into DOPs. But I noticed that it creates multiple DOP objects with same name, which I am not sure is ok. (Maybe it slows down sim?) How do I delete constranints? I need to remove objects from simulation which reach certain bounding box. The problem is that in Constraint Network I have Overwrite with SOP set to 1, because constraints are created dynamically for imported objects. When I try to delete them with POP Kill, or custom SOP Solver, their position resets to zero and it affects other connected objects. Thanks, Juraj Quote Link to comment Share on other sites More sharing options...
