Importing an Attribute via Parameter Node
ChrisL
Im trying to pull in an attribute I created into a vop material with the Parameter Node.
I tried finding some info on it, and from what I've read, if you make the name the same as what you created the attribute as in the AttributeCreate node, it should pick it up automatically, grey everything out and import that value?
Nohting seems to happen when I do that, the value just returns zero.
Is there something I'm missing or doing wrong?
It does depend upon where the source attribute is located. Is it a Point attribute, a Vertex attribute, a Detail attribute... Try promoting the attribute  from one type to another and see if that helps. If it is a material it may need the attribute to be of the Primitive type (not 100% sure on this).
Edited by Atom
