Fractures how add textures in DOP sim?
E7P
friends I want your help, I'm starting to simulate fractures voronoi Houdini,
but I have a problem when I do simulation in the DOP network loses texture,
as I can do to bring texture to DOP network simulation
I want to achieve this result, help !!!
post-14820-0-11315000-1445577332_thumb.j
post-14820-0-52841000-1445577342_thumb.j
While you really may want to access uvs in DOPs' sopnets like SOP Solver, when using some techniques, I think you just want to bring texture back in SOPs. In either case, unpacking geometry is what you need.
Consider DOP's simulated pieces as a proxy geometry, possibly low-resed before sim, with groups, uvs, normals and other unessential attributes broken, where only simulation-related attribs are important. More convenient importing is done by using Dop Import SOP. Such as importing unpacked geometry or importing only points to save disk space. You then use this points as a second input of Transform Pieces SOP and the real geometry as a first.
