whitewater foam popping
hotdoggyurkeyam
New to houdini, and trying out the whitewater solver. I have spray and bubbles turned off, and only foam. I am noticing many are popping. Is there a solution to fix this? I attached a video below.
Also, is it common to split out spray, foam, and bubbles as different white water solvers? Thanks!
whitewater_foam_popping_h264.mov
When the foam goes under the surface they become bubbles, and vice versa. So since you've turned off bubbles they will get deleted (i think? haven't done it in a while) instead. So then naturally you will also get a lot more particles with bubbles turned on.
  • 5 months later...
