for loop H15 parallel evaluation?
MENOZ
Hello,
I was wondering if the new for loop SOP opens the possibilities (for sesi) to parallelize somehow the operations, and having something that would be similar to run different node chains in parallel.
For example in cases where the same operation is repeated on different pieces, each core could process a different set of pieces, maybe?
or to copy-stamp something, each copy is independent from the other and could be run as a separate process, and merget back at the end.
I don't know, maybe it is already doing this and I'm not aware of it, or maybe is just not doable.
