haggi Posted October 26, 2015 Share Posted October 26, 2015 Hi, I'm using the great new bake texture rop in H15. Unfortunatly if I start it from a hython commandline I get an error: "Unable to initialize UV rendering module with a camera". If I do it from within houdini, (hitting the "Render to Disk" button) everything works fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
Aaron Auty Posted October 28, 2015 Share Posted October 28, 2015 I have found that the ROP still has a camera pathed to the default "cam1". If you make a cam called "cam1" it should work! Quote Link to comment Share on other sites More sharing options...
haggi Posted February 2, 2016 Author Share Posted February 2, 2016 Hi Aaron, I just read your solution. Works fine, thanks a lot. Quote Link to comment Share on other sites More sharing options...
