Yorkst Posted October 27, 2015 Share Posted October 27, 2015 (edited) I'm following an introduction to rendering in multiple passes for an older version of Houdini. I can't repeat it within Houdini 14. I have a scene with two objects: a cube and a sphere. Each object is rendered with a separate Mantra node, box_pass or sphere_pass. The sphere_pass has box_pass as an input, and is set to render "This node and all inputs". But it renders only sphere. Also MPlay is unable to render any mantra node except the first I created. multipass.hipnc Edited October 27, 2015 by Yorkst Quote Link to comment Share on other sites More sharing options...
Skybar Posted October 27, 2015 Share Posted October 27, 2015 Try render to disk instead of mplay. It does render both, but only the last one shows up in mplay. Quote Link to comment Share on other sites More sharing options...
Yorkst Posted October 27, 2015 Author Share Posted October 27, 2015 Thank you! It works. Is it possible to preview many out nodes in MPlay? Quote Link to comment Share on other sites More sharing options...
