/V\ilo Posted November 3, 2015 Share Posted November 3, 2015 Hi, i'm new in GH and I'm trying to undeerstand how to do a simple sketch analysing connections between 4 lines. I try to explain my question: - I need to create 4 vertical lines (like the edges of a rectangle) - Divide the rectangle into X floors (so i have 4 points for each floor) - Create a polyline that start from one point at the base and randomly grow up along this series of points without passing two times on the same point (like a ramp) I attach a file to better understand. Quote Link to comment Share on other sites More sharing options...
michael Posted November 3, 2015 Share Posted November 3, 2015 this is a Houdini forum - not a Grasshopper forum... if you're using Houdini you could try a grid SOP - set to 2x2 duplicate SOP - num copies to 3 add SOP - play with the By Group Quote Link to comment Share on other sites More sharing options...
