Selection with decreasing point allocation
Follyx
please, how could I distribute scattered points in a selected circle area with a decreasing allocation, depending on a ramp?
Also a solution with a SDF would be fine. VEX or Vop - doesnt matter.
That would be great.
Thanks in advance.
you'd need to push the ramp values onto the points of your geo before your scatter and then use the attribue that contains those values as your density attribute.
use a point vop to get the values from the ramp onto the points.
Edited by fathom
