Strooja Posted November 5, 2015 Share Posted November 5, 2015 Hi Guys i have a simple scene. I have a fractured object and i set the active attribute to 0 . A sphere fly through the fractured object and every touched pieces switch his active attribute to 1. In sop it works fine.But the problem is in dop nothing happen. So no piece fall down. I tought it works with "Overwrite Attribute from Sop". What do i wrong? I hope you can help me Thanks in advance Quote Link to comment Share on other sites More sharing options...
Tyfx567 Posted November 25, 2015 Share Posted November 25, 2015 Lay down a sop solver and hook it up to the presolve (middle input) of your rigid body solver. put the method of making the active attribute to 1 in that sop solver. Hit play and it should be fixed. The problem is that dops does not read information from sops every frame. That is what the sop solver is for. 1 Quote Link to comment Share on other sites More sharing options...
