Transfering velocity from volume to polygons
Hi folks!
I've done a sim of an rocket exhaust using smoke solver.
Using VDB tools I converted that smoke to polygons, due to art direction (catroon style project).
That mesh only has P attributes. The "vel.x", "vel.y" and "vel.z" are also present, but I imagine mantra needs "v" attribute on points to do geometry motion blur.
I'm not sure how to transfer vel fields to points.
My approach:
After meshing the smoke, I've put down a PointVOP
Inside PointVOP, I used three VolumeSample nodes to read the vel.x, vel.y and vel.z at the given point position.
I merged those volume samples into a vector and plug it in to "v" output.
It does give mi velocity on points, but when I render, there are artifacts present.
Can you suggest me another workflow for transfering velocity?
Oh, there is a SOP for that:) Didn't know it existed. Thanks!
It is doing what I want, but the artifacts remain. The artefacts are long motion blur streaks in different directions at the source emitter. I think it has to do with extreme velocities in smoke source. The funny thing is, when I render volume (before converting to polygons), there are no artefacts.
I attach .hipnc to clarify my problem.
Cheers!
Smoke_hoverboard.hipnc
Edited by Muhc
It's probably because the mesh is sampling values at specific points in the velfield. If you are unlucky you might have two neighbouring points on your mesh with total opposite velocities. I tried smoothing the velfield (like you did with the density) and it looked better, not sure if it works for you though. You could try that. You can also Smooth SOP the v on your mesh. Maybe both together :)
