j00ey Posted November 12, 2015 Share Posted November 12, 2015 (edited) Hi I've got a COPs problem to which I'm sure there must be an answer. I have a CHOP with some noise, the sample length is derived from the YRES of a COP. Then in COPs, inside a VOPCOP I'm trying to use the noise to sample different parts of the image. It's a distortion effect essentially. I put down a COPinput and promote the V parameter, then I need to write some expression to get the correct sample from COPs - something like chopi("../noiseGenerator/OUT/noise",$V) but I don't seem to have a $V or $Y or $IY or anything suitable. Can anyone tell me what I'm missing? Thanks in advance * edit * Test scene attached sample_CHOPs_problem.hip Edited November 12, 2015 by j00ey Quote Link to comment Share on other sites More sharing options...
kgoossens Posted November 13, 2015 Share Posted November 13, 2015 Something Like this? sample_CHOPs_problem-kim.hipnc 1 Quote Link to comment Share on other sites More sharing options...
j00ey Posted November 13, 2015 Author Share Posted November 13, 2015 Hi Kim Thanks very much - that's an ingenious solution! I was trying to avoid the pixel COP, it being so slow, but at least it works! I'm amazed that there's no U and V variable that I can use directly on the VOP, it's like not being able to do $PT/($NPT-1) in SOPs. Thank you again Quote Link to comment Share on other sites More sharing options...
j00ey Posted November 13, 2015 Author Share Posted November 13, 2015 I got this to work in my proper scene but I had to use another workaround - when I switched to a different resolution it was computing the red colour in a few buckets but most of the image was black so what I did in the end was to render out temporary files from the pixel COP then read them back in before the VOP - I thought that wouldn't work inside an HDA but it did... Thanks for the help! Quote Link to comment Share on other sites More sharing options...
