tricecold Posted November 17, 2015 Share Posted November 17, 2015 So I have this wedges of nearly 1000 sims baking on the farm. I would like to load them back with several filemerge nodes but with frame offsets inherited from a Cd attribute in the scene. I thought of doing this with file instancing and baking the offset and cache numbers as attributes, but this will only work for Mantra, I will have to export this geometries out of Houdini with the offset. Any ideas ? Also the sim needs to hold its first frame until the frame offset value is reached. Quote Link to comment Share on other sites More sharing options...
anim Posted November 17, 2015 Share Posted November 17, 2015 you can still do it with pointcloud with instancing attribs (orient, pscale, ...) and string attribute containing file path (with offsets however you want) then just use Instance SOP using that attribname it will load geometry for all the points as packed disk primitives, then you can unpack or whatever Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 17, 2015 Author Share Posted November 17, 2015 thanks Tomas, I will give it a go now. Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) you can still do it with pointcloud with instancing attribs (orient, pscale, ...) and string attribute containing file path (with offsets however you want) then just use Instance SOP using that attribname it will load geometry for all the points as packed disk primitives, then you can unpack or whatever Worked like a champ.However, another issue came to rise due to super high amount of bgeos created. Instead of bgeos sequences I am thinking of wedging into alembics. With alembics thou I would have to somehow offset the alembics cache frame without using the cache offset in the string attribute ? Anymore ideas? Edited November 17, 2015 by tricecold Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 18, 2015 Author Share Posted November 18, 2015 (edited) So I had some progress on this. I have points where I instance to abc files on disk, previous version was using a string to offset the bgeo sequence, but since abc loads a single file this wont work. Documentation shows that alembic has sample time which must be divided by fps from the current frame. But any ideas on how to make this work on point instancing. Edited November 18, 2015 by tricecold Quote Link to comment Share on other sites More sharing options...
anim Posted November 18, 2015 Share Posted November 18, 2015 (edited) you can either hack into Instance SOP replace File SOP with Alembic sop and copystamp frame from some attribute on your points or just let it copy alembics without time offsets while keeping them as delayed load alembics vary primitive intrinsic abcframe on them (e.g. using prim wrangle), that needs to be in seconds though then you can convert to polys as you wanted Edited November 18, 2015 by anim 3 Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 18, 2015 Author Share Posted November 18, 2015 Thnx, I will give both a try, appreciated Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 20, 2015 Author Share Posted November 20, 2015 you can either hack into Instance SOP replace File SOP with Alembic sop and copystamp frame from some attribute on your points or just let it copy alembics without time offsets while keeping them as delayed load alembics vary primitive intrinsic abcframe on them (e.g. using prim wrangle), that needs to be in seconds though then you can convert to polys as you wanted second advice worked like a breeze, all I have to do is to figure out how to have this offset working with delayed load procedural thnx Tomas Quote Link to comment Share on other sites More sharing options...
anim Posted November 20, 2015 Share Posted November 20, 2015 Until you unpack, it's Packed Alembic, which is automatically rendering as delayed load from disk so in theory you don't have to do anything Quote Link to comment Share on other sites More sharing options...
tricecold Posted November 20, 2015 Author Share Posted November 20, 2015 Must have done something wrong then, I will check Quote Link to comment Share on other sites More sharing options...
anim Posted November 20, 2015 Share Posted November 20, 2015 Yes, don't convert to polys, I just mentioned that since you wanted to export actual geometry, but if you want to render directly in Mantra keep it as Packed Alembics Quote Link to comment Share on other sites More sharing options...
