JesseVFX Posted November 18, 2015 Share Posted November 18, 2015 (edited) hey guys i'm a new Houdini user,i'm doing a fluid project. wish i could get some help from you,thanks first! The main problem is that when I increase particle separation from 0.01 to 0.0045,the results are quite different,i didn't change any other parameters here are images ,the separations are 0.01 and 0.0045 why it looks like this?did Iforget something ? Edited November 18, 2015 by JesseVFX Quote Link to comment Share on other sites More sharing options...
JesseVFX Posted November 19, 2015 Author Share Posted November 19, 2015 please give me some advice Quote Link to comment Share on other sites More sharing options...
Atom Posted November 19, 2015 Share Posted November 19, 2015 (edited) That is the nature of fluid simulation. Don't spend a lot of time at a resolution that is not your final resolution. You need to work at the resolution that you are going to render at. Fluid resolution is not an A-B switch where you can just turn it up after your done. Fluid resolution affects all the calculations in between as well. Become familiar with how to write out your surfaced fluid to disk. Then you can use the file node to read that info into your scene and get better scrubability or playback. Edited November 19, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
JesseVFX Posted November 20, 2015 Author Share Posted November 20, 2015 (edited) That is the nature of fluid simulation. Don't spend a lot of time at a resolution that is not your final resolution. You need to work at the resolution that you are going to render at. Fluid resolution is not an A-B switch where you can just turn it up after your done. Fluid resolution affects all the calculations in between as well. Become familiar with how to write out your surfaced fluid to disk. Then you can use the file node to read that info into your scene and get better scrubability or playback. oh got it,thank you so much Atom!!! BTW,what should I do if I want a result looks like 0.01 when the separation is 0.0045? i changed some parameters but I can't get what I want Edited November 20, 2015 by JesseVFX Quote Link to comment Share on other sites More sharing options...
dpap Posted November 20, 2015 Share Posted November 20, 2015 Increase the minimum substeps on your flip solver node Quote Link to comment Share on other sites More sharing options...
JesseVFX Posted November 21, 2015 Author Share Posted November 21, 2015 Increase the minimum substeps on your flip solver node thanks for your reply Dim! it works! Quote Link to comment Share on other sites More sharing options...
