rohandalvi Posted November 21, 2015 Share Posted November 21, 2015 (edited) hi, I need some help. I have an old file which uses the old foreach node. The file is basically a bunch of boxes which stack one on top of the other. The foreach loop essentially reads the size of every previous object and applies it to the next object effectively making a stack. I'm trying to recreate it using the new For each system, but I'm drawing a blank. If someone could look a the file and let me know what to do I'll be most grateful. regards Rohan Dalvi foreach_stackobjects_feedbacksystem.hipnc Edited November 21, 2015 by rohandalvi Quote Link to comment Share on other sites More sharing options...
anim Posted November 21, 2015 Share Posted November 21, 2015 (edited) here is a file with 2 methods 1. literally converted your setup to new loops 2. simpler and more efficient way foreach_stackobjects_feedbacksystem_fix.hipnc Edited November 21, 2015 by anim 5 Quote Link to comment Share on other sites More sharing options...
rohandalvi Posted November 22, 2015 Author Share Posted November 22, 2015 Oh man, thank you so much for this. Your file taught me quite a few new things, like I never figured out how to convert groups to name attribute. Thank you once again. I might be using part of this technique in a small tutorial, I'll definitely be mentioning you. regards Rohan Quote Link to comment Share on other sites More sharing options...
