zarti Posted November 25, 2015 Share Posted November 25, 2015 hi everyone ! as title 'said' .. i cannot dynamically ( after-getting-value-from-somewhere-else ) set minValue / maxValue of a parm . it is an IntParmTemplate ; i can read, manipulate but not "replace" . after searching through forum best i could find something similar ( asked some days before ) but it applied to a parmTemplateGroup . sorry i cannot copy paste since im posting from tablet but my code is something like this : nd = hou.node( 'somepath' ) ptg = nd.parmTemplateGroup() i = ptg.find( 'myintparm' ) i.setMinValue( int( min ) ) i.setMaxValue( int( max ) ) ptg.replace( 'myintparm', i ) nd.setParmTemplateGroup( ptg ) # parms do not change !! what im doing wrong ? it sounded simple when i started to do it , .. but here i am =) ! thaks in advance Quote Link to comment Share on other sites More sharing options...
zarti Posted November 25, 2015 Author Share Posted November 25, 2015 .. additionally ( and strangely ) , when i use "append" instead of "replace" it seems to work ( a new parameter with min&max values assigned by me ; is created as it should ) ? strange Quote Link to comment Share on other sites More sharing options...
anim Posted November 25, 2015 Share Posted November 25, 2015 you can modify only spare parameters so if you are trying to change parameters that are in definition of the node it will not work as you are not able to change them through Edit Parameter Interface either that's why appending works as it is appending a spare parm but if you try to modify spare parm, it should work as you have it 1 Quote Link to comment Share on other sites More sharing options...
zarti Posted November 26, 2015 Author Share Posted November 26, 2015 first of all, thank you for your reply ! it was Really helpful for not wasting more of my time floating between my ignorance <-> thin documentation <-> searching on forums . you can modify only spare parameters so if you are trying to change parameters that are in definition of the node it will not work as you are not able to change them through Edit Parameter Interface either that's why appending works as it is appending a spare parm but if you try to modify spare parm, it should work as you have it i built a clean SOP_Python DA just to test "how many points has the input node to my DA" and it really worked . min and max integer values are updating correctly with the help of 'clear()' method . i need to find a way trigger the updating the values , but that appears to be easy trying tricks . changing defined parameters not be a limitation in houdini , imho , but anyway .. i'll post the code later since i havent yet found one on forums fully illustrated for future reference to someone like me , or even for me only . who knows where this DA will end after some time .. =} thanks again anim ! -- second - just few thoughts after this experience ; ? Why there exists a 'second-class-citizen of parameters' ? is this because of some limits of parameters defined in a DA or spareParameters have extra-special-Powers ? another open question is : where i can find a concise list of " where Spare Parameters should / should Not be used " ? this seems important and i can read about it superficially here-and-there in some docs paragraphs / forum posts .. but this is not how i do store it in my permanent brain memory . spare parms and similar exclusive houdini terms / jargon , IMHO , should be specifically Defined in some official place ! maybe im missing something simple , but all i know for sure is ; the time i consumed to solve this situation ( or similar ones ) would have been better spent producing 'nice outputs' . while i appreciate SESIs efforts to make houdini's viewport interactivity , shading and rendering more powerful and conventional i think a new ( important ) front should be open in the documentation and referencing system . this would be tremendously helpful in countless tasks everyday ; especially for generalists . if the Power of Houdini is 'hidden' in constructing Digital Assets , then building DA UIs should be simply .. SPECTACULAR . .. sounds like a rant , but sincerely it is a critique . .cheers Quote Link to comment Share on other sites More sharing options...
