bestxhh Posted November 27, 2015 Share Posted November 27, 2015 Guys hi In the particle, how can I get the particles to enter a certain group, and then calculate the $AGE? I have some points. It's black. Now. There is a red ball passing through these points. I now want to add a $AGE attribute value to these points is $T But I would like to make these points at the beginning of the red will be calculated from 0 $T, and I now all the $AGE attributes are the same value What should I do? thanks.. Quote Link to comment Share on other sites More sharing options...
Tyfx567 Posted November 27, 2015 Share Posted November 27, 2015 (edited) Ah ok. file included. hopefully this is what you meant. you make a group in a sop solver in particles, the sop solver evaluates every frame, that group continues even after the sphere has past. Not sure if that is what you are after. Then there is a solver node which lets you make a count and make it say "if inside the sphere group, increase this count number to time" (starting at 0 like you requested). The way you make it start at 0 is make one variable that starts a count starting at 0. To make the offset of time, you make another variable that takes that count variable and divides it by $FPS. Next is an example in another wrangle that shows deleting particles after certain age count_particle.hiplc Edited November 27, 2015 by Tyfx567 Quote Link to comment Share on other sites More sharing options...
