MarXindia Posted December 3, 2015 Share Posted December 3, 2015 Hi, I am trying to render Maya ASS file with textures in Houdini using Arnold procedural and instance nodes.I am getting the geometry but textures are not coming. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 3, 2015 Share Posted December 3, 2015 You probably need to add the maya shaders to your shader path. We had to do the reverse when rendering houdini ass files through maya. 1 Quote Link to comment Share on other sites More sharing options...
MarXindia Posted December 5, 2015 Author Share Posted December 5, 2015 Hi Erik, Thanks,that was the problem.Houdini is rendering the shaders now but I am caught up with another one.Houdini is not rendering the aLsurface shader from Maya where as its rendering the aistandard.And the files we received from lighting uses aLsurface shaders.I tried to recreate same using aistandard but parameters are different and few not available in aistandard.Do you have any idea about that? Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 5, 2015 Share Posted December 5, 2015 You could add the aLshaders the same way as the regular arnold shaders afaik 1 Quote Link to comment Share on other sites More sharing options...
