logix1390 Posted December 6, 2015 Share Posted December 6, 2015 Hey everyone, I have a quick question about particle mass. Basically when I add mass to it using the pop property I don't see any difference when I play it. I created two emitters , each with different mass values, however they both emit at the exact same rate. Shouldn't one go slower than the other with my given values? I attached my file here if someone wants to take a look. I am using Houdini 14. Thank you particle_mass.hip Quote Link to comment Share on other sites More sharing options...
sekow Posted December 7, 2015 Share Posted December 7, 2015 (edited) implement some (pop) drag and uncheck ignore mass. or delete the gravity force dop and put in a pop force (dont forget to uncheck ignore mass) but I agree: F = m * a a = F/m it should differ. Edited December 7, 2015 by sekow 1 Quote Link to comment Share on other sites More sharing options...
logix1390 Posted December 7, 2015 Author Share Posted December 7, 2015 Hey thanks for the reply. I tried it out and it works.But Is their a way to fix this mass issue so that I have proper attributes. Seems like adding force to it is just a quick fix. Thanks Quote Link to comment Share on other sites More sharing options...
