Problem compiling H15 samples - solved
You must compile with 2012.
You can compile with hcustom with 2012 express but you need to set it up first.
1. Copy cl.exe (the actual .exe file, not the xml config file name cl.exe) from C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin  to  C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\amd64
2. Every time you launch the hcustom window you must first run C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64\vcvarsx86_amd64 from the hcustom command prompt
Let me know if that's not clear or not correct...
Yes, there was a confusion with version numbers, partially caused by MS numbering: VS2015 containt vc14, VS2013 - vc12, and for some reason i thought H15 is using vc12.
Will try vc11 in a few.
But yep, some error message in console about version mismatch or macroed compile time error would be useful.
