ChargingImage Posted December 11, 2015 Share Posted December 11, 2015 (edited) I'm looking for a node that reads all layers from file, and shows them in one image (example from nuke in attachment). Does this node exist? Edited December 11, 2015 by ChargingImage Quote Link to comment Share on other sites More sharing options...
mupapabear Posted December 11, 2015 Share Posted December 11, 2015 (edited) You mean like the layer contact sheet in nuke? Would be interested to know as well. Edited December 11, 2015 by mupapabear Quote Link to comment Share on other sites More sharing options...
symek Posted December 11, 2015 Share Posted December 11, 2015 I don't think there is such node. Mosaic does similar thing but puts together sequential frames, not planes. Example Vop setup attached. It's a matter of RMB-> VEX/VOP Options-> Compile VEX Code to COP2 Type to have custom hda from this. Adding captions with planes names would require little magic with python and Font COP. Good exercise hth, skk. layerContactSheet.hipncFetching info... 1 Quote Link to comment Share on other sites More sharing options...
ChargingImage Posted December 14, 2015 Author Share Posted December 14, 2015 (edited) Thanks Symek, looks good. You did that? edit: I wonder could this "channel copy" be directed by script. Once I did simple switch expression for otl, that said: if @name exist -> use name, if doesnt -> ignore. This prevented the error in nodes. In this case, I would like to build setup that copy channels ony if they exist. Less manual work - better. Edited December 14, 2015 by ChargingImage Quote Link to comment Share on other sites More sharing options...
symek Posted December 14, 2015 Share Posted December 14, 2015 What kind of errors you have? This was 10 minutes try, so there is good change it's buggy but ChannelCopy is redundant. I've used it only to have more channels inside picture available. Only last node (VOP Filter) is what you're after. Quote Link to comment Share on other sites More sharing options...
ChargingImage Posted December 15, 2015 Author Share Posted December 15, 2015 No, no - I don't have any errors in this case. I'll make some tests and get back if there will be problem (or a solution ) Quote Link to comment Share on other sites More sharing options...
