Use dual rest fields without Unified noise in H15?
Neon Junkyard
I have a smoke sim from pyro with dual rest fields, and I want to use the rest fields as my sample source for a custom noise in a volume VOP.  However with Houdini 14+ the dual rest solver only seems to work with unified noise as it has two outputs, or in houdini 15, a signal output.  I need to create my own custom noise for this project, and the unified noise isn't cutting it.
With older versions of houdini you could use a mix to blend between rest and rest2 using rest_ratio as the bias (see attached for a simple example) but this no longer seems to work and causes popping in the noise as the rest positions change, as it doesnt account for rest2_ratio, or rest2 in general (or so Im guessing).
Both the dual rest solver and unified noise have been black boxed in Houdini 14+, so does anyone know how to either-
A- recreate the dual rest solver using regular vops
or
B- get the dual rest solver to work with regular turbulent or anti-aliased noise?
Thanks!
post-12349-0-37805400-1452132796_thumb.p
Edited by dparks88
