point_smoothing
3__
hmm, I'm trying to smooth geometry using
vops but there doesn't seem to be a way
to store the positions of connected points
before averaging. I'll also need to store the
averages before applying to avoid biasing.
is this a job for typed code or does vex still
not support arrays? any other workarounds?
-cpb
Please take a look at the attached file.
- To get a an input's point positions, use an Import Attribute VOP with a Vector attribute named "P". Think of this as similar to the point() expression function.
- I'm not sure why you would need to store your average. If you're trying to do multiple average passes on your point data, then yeah, you'll have to just apply the VEX SOP as many times as you want iterated. You could always use Simon Barrick's Loop SOPs HDA.
sop_lowpass.zipFetching info...
  edward said:
PS. I assume you already know about the Smooth SOP.
15846[/snapback]
yep, just wanted to combine iterative smoothing with a
self-shadowing tool that relies on a relaxed input. I'll
just use the smooth sop for now.
-cpb
