2 more questions
lanchka
revolve sop for lathing and curve sop
for splines. there's a freehand option
in the curve sop. also no tangent handles
or per-point tangent settings (smooth, corner,
bezier etc.), the entire spline has to be one
or the other. convert to poly and use polywire
to emulate renderable mesh settings.
also missing are handy editable-spline tools like
boolean and outline, but there may be work-arounds.
-cpb
@lanchka
1) Curve SOP. In the parameters dialog, you can change the type for NURBS or Beziers. Don't forget that you can also change the method between CVs and breakpoints.
@cpb
I'm not sure what you mean by not having boolean or outline. What about the Cookie SOP? For outline, do you mean having open primitives? If you drew a closed primitive using the Curve SOP, you can just append an Ends SOP and set the Close U parameter to Unroll. There's also other opens in th e Ends SOP for opening up primitives.
in editable-spline from max there is a spline
boolean option (as an editable spline can contain
several splines). In houdini I haven't found a
way to boolean curves except for hole which only
works when one curve encloses another.
the border sops over in codex might perform an
outline of a curve, but I've yet to properly install
either of them...
-cpb
