Instancing multiple geometry
You can create a point attribute called 'instance' who's value is the path to the object inside Houdini, or 'instancefile' with a path to the geometry on disk. If you put the below code in to an attrib vop you should get 20% of your points pointing to instance2 object and 80% pointing to instance1.
if(rand(@ptnum)>0.2)
        s@instance = "/obj/instance1";
else
        s@instance = "/obj/instance2";
This video from Sidefx covers everything you need to know about instancing.
