Fluffy Pyro
shrifazmy
Looks awesome! What is it? ;)
Well, something is off, obviously, either the shader, you have something messing up density, or you mistakenly set the wrong node as output somewhere. Juraj is right, hip would help a lot.
Edited by Farmfield
Yes turn anything OFF that may rip apart your volume such as disturbance and dissipation (or lower that value). Verify your gravity, boyancy and velocity are not conflicting in directions or speed. And make sure your density on your source is dense enough that your volume isn't too wispy to really take a fluffy shape, you want a dense enough volume to take a fluffy form.
