FEM using a velocity field
cgcris
Hi guys,
wondered if it was possible to control the direction of a snake type FEM with a velocity field.
I know I can use a sopsolver, and then set a custom force, but wondered If I would better results using a field.
anyone know if this is possible?
What I am trying to replicate is something like a carpet of snake, like in this clip. besides the snakes having their own movement, I need an overall direction path/direction
https://youtu.be/VVgReLN2g8k?t=55
Edited by cgcris
Naeh, I'm thinking I'd create a crawl-loop on a spline then use that for a goal for the FEM, somehow, then have it crawl on it's own - kinda like in this setup...
Particle Skull also did a self crawling FEM setup, so it works, now you only have to figure out how to best create the snake like motion instead or worm- or snail-like...
