Differences in N with point and pointwrangle node
Follyx
Trara... Eieiei... Thank you.In the beginning its so mucht to take care about.
Thank you.
How could I organize groups in a PointWrangle node? So to get exactly the same as in the point node?
Edited by Follyx
You can use same group technique with two nodes. It is faster to do and more readable in network (you need to notice specified groups, however). In VEX there are several ways, maybe more than those three:
// Comparing against point number in VEX.
if (@ptnum == 0)
    // Code.
// If using _existing_ group.
if (inpointgroup(0, "groupname", @ptnum))
    // Code.
// Using bindings. No need to use functions for points, vertices and prims.
if (@group_groupname == true)
    // Code.
