Separate surface tension and meshing for two FLIP emitters
quryo
I'm trying to simulate 2 fluids that don't mix, but still interact with each other (similar oil and water).
The meshing to some extent works by selecting the particles based on the emitter group (stream_source_surface_from_...) and then ensuring that they don't overlap after converting to a VDB with VDB combine.
However, it would be nice to also be able to apply things like surface tension on both fluids separately. I tried my luck with the group field of Gas Surface Tension, but somehow I'm not able to put the two fluids in separate groups. I'm also not sure what the correct group name would be.
I also tried using two separate FLIP solvers merged with a Collide relationship, but the two fluids don't actually interact.
Thanks
Edited by quryo
