unselected second normal point
Follyx
is this right?
If I create a normal and define just one point, Houdini assume that the other is selected at {0,0,0}?
And is this valid for polylines and other objects too?
And how can I reverse a normal and a polyline in an attribwrangle?
Edited by Follyx
1. Yes, some "default" values will be assigned to points outside selection. If you haven't created an attribute with specified default value, most of the time it will be zeros.
There is some special defaults for attributes like in id, where 0 is a normal value for first enumerated element, so, default here should be -1 to avoid collisions. If you create id by wrangling over subset of points, default for all other points will be -1. From my experience, all "known" special defaults assigned to same set of attributes with "assumed datatypes", for which we can write @P in a very first time in code, without need to specify it's type. Here the full list of them. Most of them still logically have defaults of zeros, however.
// Assumed integer with default of -1, a special attribute.
@id = @ptnum;
// Float with default of 0.0 because we didn't specify a type.
@my_id1 = @ptnum;
// Integer with default of 0.
i@my_id2 = @ptnum;
@my_id2 = @ptnum+10000; // No need to specify type again.
i@my_id2 = @ptnum;      // But nobody said we can't.
// Declare and assign custom attribute like @id.
int @my_id3 = -1;
@my_id3 = @ptnum;
2. For reversing part.
Primitive Wrangle:
// To reverse vertex numbers per polygon, like in Reverse SOP.
int pts[] = primpoints(0, @primnum);
foreach (int i; int pt; reverse(pts))
    setprimvertex(0, @primnum, i, pt);
// To reverse point numbers per polygon.
    removepoint(0, pts[i]);
    setprimvertex(0, @primnum, i, addpoint(0, pt));
// To reverse point positions per polygon.
foreach (int i; int pt; pts)
    vector pos = point(0, "P", pts[-i-1]);
    setpointattrib(0, "P", pts[i], pos);
To reverse like in Sort SOP use Detail Wrangle:
// To reverse both point and primitive numbers.
for (int ptnum = 0; ptnum < @numpt; ptnum++)
    removepoint(0, ptnum);
    addpoint(0, @numpt - (ptnum + 1));
for (int primnum = 0; primnum < @numprim; primnum++)
    int pts[] = primpoints(0, primnum);
        setprimvertex(0, primnum, i, @numpt + pt);
// To reverse point numbers.
for (int primnum = @numprim - 1; primnum >= 0; primnum--)
    int newprim = addprim(0, "polyline");
    removeprim(0, primnum, false);
        addvertex(0, newprim, @numpt + pt);
// To reverse primitive numbers.
    foreach (int pt; pts)
        addvertex(0, newprim, pt);
To reverse vector, just negate it: @N = -@N.
reverse.hipnc
Edited by f1480187
  • Like 2
