AdamJ Posted January 27, 2005 Share Posted January 27, 2005 Hi all, I'm having trouble getting the callback script to run properly. It's suppouse to duplicate a few nodes when the user presses the button. Problem is that the callback script doesn't seem to finish unless I type in the texport 'end'. What I'm after is for i = 1 to 4 opcp node_0 node $i; end but when trying to run this from callback the 'end' has no effect. Is there another way I should be doing this? Any tips and suggestions are appreciated. Adam Quote Link to comment Share on other sites More sharing options...
AdamJ Posted January 27, 2005 Author Share Posted January 27, 2005 .. in case anyone is interested.. I got it working by including the scripts in the HDA and then opdef them in the callback line. Seems Houdini had a problem with having the entire script as one line in the callback field. Quote Link to comment Share on other sites More sharing options...
old school Posted January 28, 2005 Share Posted January 28, 2005 Tip and suggestion? How about trying the help in the textport for proper if useage. Here it is for you: / -> help if if Usage: if (condition) [then] The if construct. If the condition is met, then the contents of the if statement will be executed. An endif statement is required to terminte the if clause. For example: if ( $F == 1 ) then echo Frame One else echo Another frame endif Note: In the current implementation, the statements for the if clause must occur on separate lines. That is, statements like "if ($F == 1) echo Frame One" will not work. As you can see, endif is the terminator for the if statement in hscript. Quote Link to comment Share on other sites More sharing options...
AdamJ Posted January 28, 2005 Author Share Posted January 28, 2005 yep that was the problem .. the if/for/end statements have to be on seperate lines.. read the 'for' help, didn't read 'if' help ...doh! Quote Link to comment Share on other sites More sharing options...
michael Posted January 28, 2005 Share Posted January 28, 2005 ...in the HDA and then opdef them in the callback line are the nodes duplicated in the hda?...or just in the houdini session? Quote Link to comment Share on other sites More sharing options...
AdamJ Posted January 28, 2005 Author Share Posted January 28, 2005 They are getting copied in the houdini session. Quote Link to comment Share on other sites More sharing options...
