Emit smoke in object's local direction?
cwalrus
Hi -
(I feel like this has a simple answer and i am having trouble figuring it out.)
I just want smoke to come out of a torus, let's say along it's local Z axis. And then when I animate the torus, the smoke will continue to be emitted in that direction, changing along with the rotation of the torus.
I can get the smoke to emit only in velocity of Z, but I believe that's in world space and doesn't care about the local rotation of the torus.
Anyone know how?
thanks!
You're leaving out a fir bit of information. It's usually easier to understand a problem with a hip file.
How are you animating the torus? In Houdini? Alembic Cache?
If it's in Houdini, just assign your velocities before your transform and it should update properly.
Edited by 3iart
Hey there - one issue. The transforms I am required to follow are baked on the geo level - How do I get them inside my obj - onto the transform there? See attached file - it will make sense what I"m trying to do:
Think of an exhaust pipe behind a car...
Thanks!
cameron
