Pyro Volume collision
Hi
am trying to make this pyro sim but i have a problem with the geometry collision
here is a screen shot
This white objects is an animated alembic objects
its moving something like a tentacles
i used the volume collision but its not use the same shape for the object
it only use the boundary box of the geometry as you can see i think i miss something with setup
how i can achieve the effect
here is a screen shot of my setup for the collided objects
and  here on the sim network
Ya i know and i wish if i can send a sample but the alembic file is huge and when i try to replace it with mesh its not the same effect
any way i think i catch the reason of my problem but i cant figure a solve yet
my problem is here with fluid source node
i need a high division size so i can get the correct volume shape but this will slow my sim
i was thinking to replace it with vdb nodes but i dont no how to achieve this
One thing I'm noticing is that you're piping the collision volumes right into your pyro solver instead of using Rigid Body Static objects, which is a lot easier to setup. See attached file.
- Use a VDB from polygons to convert your geometry to a VDB; adjusting the resolution so that the shape is well defined.
- After selecting the parent node that holds that geometry/VDB, use the Static Object shelf tool to setup the rigid body DOP nodes for you.
- Go into the DOP network, and on the Static Object node go to Collisions Tab --> RBD Solver Tab --> Volume Tab, and make to "Mode" is set to Volume Sample. This ensures that the VDB you created is used for the collsiion geo.
- Also make sure you check "Use deforming Geometry" in the Static Object node to ensure that the tentacle movement is recognized.
RigidBody_Obstacle.hiplc
Edited by LukeLetellier
