Delete only one chunk in voronoi fracture..
cwalrus
Hey peeps -
does anyone know how to delete one piece out of a voronoi fracture? Basically I want to make the main large chunk static, and have the other pieces animate around it. Don't know how to select it / separate it out...
thanks!
Here's a file showing how you measure the area for each piece.
Only thing I didn't do at the end was isolate the largest piece in any sort of clever way I just sorted the spreadsheet to get the largest value. I'm sure there's a clever way to sort it and automagically get the largest value :)
Also I have a question too! In the file I have a blast and delete node with the same expression. Why is it the blast node seems to work but the delete node's expression doesn't?
measure_area.hipnc
