cwalrus Posted February 9, 2016 Share Posted February 9, 2016 Anyone figure out why this crashes when you turn on interior details? Also, how do you access the interior surfaces so that you can texture them separately? thanks! HutCHop.hiplc Quote Link to comment Share on other sites More sharing options...
rbowden Posted February 9, 2016 Share Posted February 9, 2016 Just tried it on my end using Houdini 15.0.347 and it worked ok with no crashes. Took about 3 minutes to calculate the inside faces. What version of Houdini are you using?Also, you get inside and outside face groups with the voronoi fracture SOP. You can look at/change the names under the groups tab (right beside Interior Detail tab).-Ryan Quote Link to comment Share on other sites More sharing options...
cwalrus Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks so much - I just figured out that it automagically makes inside and outside groups for you. Sweet! Also, i don't know why but it crashes on two different computers here- but they are both macs, I guess... I turned the Volume resolution up, and oddly enough, the interior detail worked that time! Check it so far: http://guerrillaanimation.com/videos/2016_Houdini.mp4 Quote Link to comment Share on other sites More sharing options...
